Aconda
Discussion in 'General TV Discussions Forum' started by gary., Sep 10, 2001.
  1. gary.
    gary.
    Hi guys.<br /> I have a Loewe Aconda,which I love.<br />I think Loewe have a new life long customer<br />here.<br /> My question concerns my Dvd player,its a first<br />generation panasonic A110.(US player).<br />Would I gain much picture quality by upgrading to<br />a high end player?<br /> Not to mention it will not play Aliens.Out of all<br />the films.In cyberspace can you here me scream?<br />Thanks<br />gary
  2. Garrett
    Garrett
    Apr 21, 2001
    41,186
    2
    167
    The best thief you’ll never see.
    +7,111
    Hi Gary<br />I cannot answer your question but here’s my view.<br /> I have a Aconda to which is connected a Grundig 210A (£160-£230)DVD player and all I can say I’m well suited. <br />Can you try testing you DVD player at some shop that sells Loewe TVs against a higher grade DVD player. Or if you know someone who you think has a better player ask them round with their player(show them what it looks like on a good TV), but don’t tell them that, they might get upset.<br /> <img src="cool.gif" border="0"> Ruby quartz shades.
  3. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    With the Aconda you have the option of a VGA input. What about putting the progrssive scan VGA output of a Skyworth into this?
    Does it work? If it does it should be unbeatable as a combination.
  4. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,210
  5. Gordon @ Convergent AV
    Jul 13, 2000
    14,209
    +3,046
    Nic,
    It'll work with NTSC not PAL though I would think.
    I managed to get another progressive DVD player to do VGA in to the Aconda inthe shop and also managed to get the Runco PFP-11 PROCESSOR to do it as well.
    Ideally what's required is a scaler which outputs 600 x 480 regardles on input signal. A quadscan Elite and Vigatec will do this. Runco won't downscale PAL to 480P unfortunately. If I had time I'd try Vigatec on ours... but I'm a bit busy I'm afraid.
    The Aconda is one of the best "flat" TV's around once set up properly. It should be capable of showing the difference in picture quality between DVD players.
    Gordon
  6. Lowrider
    Lowrider
    I have the Vitros, wich is suposed to be the same chassis as the Aconda. I have been told by Loewe that if you feed component video to it, only on Scart 3 on mine, it will do progressive scan, they call it Proscan, without the DVD doing it. <br />Then, advised by the Loewe technician, I changed the configuration on my Arcam DV88 to component video, (before I had it configured to RGB), and the differences where amazing, much better colours and a lot more detail on the background and shades. <br />I believe that if your DVD doesn´t have component video output, you will get a much better image with one that does, for instance the Arcam, and save the money of a progressive scan DVD, plus the money of the VGA upgrade, you need it for the progressive scan players.
  7. Gordon @ Convergent AV
    Jul 13, 2000
    14,209
    +3,046
    Hi Antonio:
    When you changed from RGB to Component did you re-set brightness and contrast and colour settings using a test disc or were the settings for Component the same as RGB?
    As far as I know Aconda's etc all run in progressive mode, regardless of input. Also they do not have 2:3 recognition so they will introduce de-interlacing artifacts with NTSC film based discs.
    Gordon
  8. gary.
    gary.
    Thanks for the replys guys.<br /> Anymore Aconda tips or hints?<br />Cheers<br />Gary
  9. Lowrider
    Lowrider
    I didn´t have to change anything. The info I got from Loewe was that it will only de-interlace with component video input, and the difference it made from RGB input confirms it, I would say...
  10. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    The firmware may have changed but on my Aconda all NTSC stuff is deinterlaced regardless of input and PAL stuff isn't, again regardless of input. Loewe tend to give completely different answers everytime you talk to them.
    Jeff
  11. dsb
    dsb
    as a new aconda owner i'll ask.....
    when people refer to it doing internal progressive scan on NTSC inputs-does it actually have to be true NTSC?
    for example i have my dvd player connected as RGB for best picture quality.
    will the tv perform progressive scan on the RGB 60hz picture from region 1 dvds or would i need to set the dvd player output to composite or s-video?
    seems a shame if i did as this would have a quality trade off.
