Aconda HD/DR+ not Hi-def then...
Discussion in 'Televisions' started by cerebros, Jan 15, 2004.
  1. cerebros
    cerebros
    Dec 27, 2002
    1,190
    38
    Leicester
    +11
    Finally got an answer from Loewe's UK distributer as to whether the new Aconda 9381 HD/DR+, described on Loewe's site as having "RealFlat HD picture tube" and "MediaPlus HD technology", is actually HDTV compatible or not.
    As you'll have guessed from the subject, the answer is no. The new set merely has "improved focus and sharpness".
    It also still accepts component only through the third SCART, and only interlaced component at that...
    The words "opportunity" and "missed" spring to mind...
