ack c2 ghosting problem.
elotunes
hi all, my problem is slight ghosting when the projector has been on for a few minutes. its not related to the source as it also shows on the menu when displayed. it starts perfectly but slowly becomes a slight double image.colours etc are all fine.i would very much appreciate any idea`s on how i might correct this problem. many thanks in advance.. Dave in very very wet Cornwall..
elotunes
just incase somebody knows. i`ve had a look around inside the projector for a method of fine tuning , a trim pot for instance or a manual adjustment to no avail . if anybody knows of such a thing could they please let me know. thanks again Dave. :lease:
G
gurj1979
I have the SAME problem, it starts off fine, but then it start ghosting the image and the brightness starts to go dim after an hour. I suspect it's the Lamp Power Supply module that is causing this, but I can't be 100% sure.
Can somebody PLEASE help us out with this. :lease:
