Achoice between two heavy weight HDTV for my 360
Discussion in 'Xbox Forums' started by Lobo Soulman, Mar 18, 2006.
  1. Lobo Soulman
    Lobo Soulman
    I have searched long and hard and have it down to two candidates.
    Both have excellent reviews and both can be bought at John Lewis with a 5 year guarantee.
    The last bit is the hardest which one to pick out of the following.
    The Toshiba 32WLT58
    http://www.johnlewis.com/Audio+and+TV/Televisions/+Televisions+/LCD/230222385/Product.aspx
    I have only heard good things about
    Or the
    Samsung LE32R41BD
    http://www.johnlewis.com/Audio+and+TV/Televisions/+Televisions+/LCD/230214498/Product.aspx
    Which again I have only heard good things about.
    I will be using for my x box 360 and ps3 (when thats here) and Tv and Dvd playback. I am wondering if the toshiba is actually the better Tv in a head to head though? Is it worth the extra price? I can find both cheaper online but not with a 5 year guarantee.
    Thanks for any help :smashin:
  2. 2scoops
    2scoops
    Feb 4, 2006
    719
    +40
    get the sammy £720 with 20% off at Freemans
    I got one it's mint the 360 looks great on it
  3. delboyuk2005uk
    delboyuk2005uk
    Dec 24, 2005
    3,580
    68
    St Helens
    +73
    am looking at the samsung 2!
    what is it like playing dvds and normal tele like sky cable stuff like that.
    freemans offer sounds the best
    do they do a buy now pay later scheme, or even a 0% finance?
  4. Lobo Soulman
    Lobo Soulman
    Thanks for your help guys, I could get it from freemans works out cheaper but call me an old git but i like the idea of a nice five year guarantee ;-)
  5. ash
    ash
    Jun 9, 2005
    11,295
    +396
    You can use 20% off for the Toshiba as well, I definately reccomend it, its more expensive for a reason, and that is that it is better, I tested them both and Toshiba wins easy, it also has better connections.
  6. delboyuk2005uk
    delboyuk2005uk
    Dec 24, 2005
    3,580
    68
    St Helens
    +73
    so how much does the toshiba hdtv come to from freemans with 20% off?
  7. Lobo Soulman
    Lobo Soulman
    Maybe I should go with the Toshiba then, lol Im swinging one way then another.
    When u said the toshiba wins easily is there that much of a difference?
  8. c3ham
    c3ham
    Sep 29, 2004
    203
    +19
    if u can go a bit extra get the JVC 32/26DX7 kicks the samsung ass. i have seen many different lcd's hooked up to the 360 side by side and the 32/26DX is the best i have seen :)
  9. delboyuk2005uk
    delboyuk2005uk
    Dec 24, 2005
    3,580
    68
    St Helens
    +73
    well how much is the jvc can you get 20% off that 2
  10. SoleFever
    SoleFever
    Nov 15, 2005
    1,789
    +55
    You really should go into a shop and have a look for yourself as it's you who will end up watching it at the end of the day. I personally dont like the JVC, i really dident think it looked all that great. Not enougth to warrent spending more on it aneyway. I have the Samsung LE26R41BD and am more than happy with it, a great TV imo. And if i had to make a choice again i would go for the Sammy.
  11. audio design
    audio design
    Mar 17, 2006
    42
    +3
    there is a real problem with using vga cable from the 360 on the toshiba,
    from what I have read in other threads.
    Huge drops in frame rate. Whilst this effects other LCD on some games slightly it is no where near as extreme.
  12. nick501
    nick501
    May 6, 2005
    7,217
    Walsall, West Midlands
    +782
  13. ash
    ash
    Jun 9, 2005
    11,295
    +396
    Well you really should be using component for 360. The VGA works perfect for PC though.
  14. Lobo Soulman
    Lobo Soulman
    Thanks a lot, I think its going to be a choice out of the two Toshibas Nick has stated.
    Roll on pay day :)
    Thanks again all for your help
