Acer has component scart input - how to connect consoles which have component input??
Discussion in 'LCD & LED LCD TVs Forum' started by Abeyance, May 17, 2005.
Tags:
  1. Abeyance
    Abeyance
    May 17, 2005
    34
    I bought an Acer LCD recently to take advantage of high-def gaming. Problem: the Acer accepts component only via a scart input (very odd) and not directly.
    My consoles component cables only connect directly to a component input. Does this mean I am doomed and can't enjoy high-def? Or is there some scart adapter which takes component as input? Do I need a VGA box? Can I use a phono to scart adapter?
    Are there any devices or solutions which you know of that can help? Would be a real shame to send the TV back.
    Thanks!
  2. dsb
    dsb
    you can buy component to component via scart leads - loewe tvs use them for example.
    whether they will work with hi-def component i couldnt say
  3. Abeyance
    Abeyance
    May 17, 2005
    34
    Thanks for the suggestion, but I already found a solution.
    A tripe phono coupler does the job. It has the composite colours on it which can be misleading but component works just fine as well. You'll need two of them though - one for the video and one for the audio output. Since audio is only two inputs a double phono coupler is suitable for that. Hope this helps someone in future.
