Acer H233HAbmid or the Samsung P2450H
snverhallen
So I've been looking at these two monitors for my PS3. From what I've read the Acer is a great monitor for the price and has very good specs. The Samsung is quite new hence the lack of review material on it. I have read two reviews translated from Chinese and they were extremely impressed with it. Like the Acer, the Samsung also has great specs.
The Acer is 23" and the Samsung is 24". I'm in Holland and the following are the cheapest prices I can get them for. I noticed the dot and pixel pitch on the Acer is .248 mm and the Samsung is .265 mm, does that make a big difference?
Which one do you think I should go for?
Acer = 180 euro - Samsung = 215 euro
Specs
Acer -
Display Size
58cm, 23" Wide 16:9 Full High Definition, 509.2x286.4 mm
Panel Technology
TN + Film
Resolution
1920x1080 @ 60Hz
Format
Brightness
300 cd/m2
Contrast
40'000:1
Viewing angle
170°(H), 160°(V) CR 10:1, 176°(H), 176°(V) CR 5:1
Response rate
2 ms
Tilt / Swivel / Pivot
Tilt: -5°~15°
Height Adjustment
Input Signal
VGA, DVI & HDMI (w/ HDCP)
VESA Wall Mounting Support
100x100mm
PPI 96
Colours 16.7M (6+HiFRC)
NTSC 72 %
Pixel Pitch 0.265 mm
Speakers 1W x 2
Power consumption
Energy Star® On: 31.7W
Off: 0.72W
Stand by: 0.76W
MTBF Hours
50000hr/25°C
Dimensions
552x408x171.6 mm
Net Weight
4.92 Kg
Certifications
CE, TÜV GS, ISO 13406-2
Free Accessories
European, UK or Swiss Power Cables, VGA and DVI cable
Samsung (from Samsung's English Hong Kong site) -
Display Screen Size 24"Wide
Resolution 1920x1080
Brightness 300 cd/㎡
Contrast Ratio DC 70000:1(1000:1) (Typ.)
Response time 2ms (GTG
Viewing Angle(Horizontal/Vertical) 170˚/160˚ (CR>10)
Color Supported 16.7M
Signal Input Video Signal Analog RGB, DVI
Sync. Signal Separate H/V, Composite, SOG
Connector 15pin D-SUB, DVI-D, HDMI
Power Power Consumption 42 Watts
Stand By Power (DPMS) <1W
Type Built-in
Features Plug & Play DDC 2B
Multimedia Speakers No
Optional Accessories DVI Cable(option)
Special Features MagicBright3, Off timer, Image Size Color Effect,Customized key, MagicWizard & MagicTune with AssetManagement,Windows Vista Premium, DVI with HDCP
USB powered hub option No
Mac compatibility Yes
Wall-Mount VESA 100 mm
TCO TCO5.0
Cabinet Color Rose Black
Dimension Product Dimension(With stand, WxHxD) 578 x 430.0 x 190mm
Product Dimension(Without Stand, WxHxD) 578 x359 x64mm
Shipment Dimension(WxHxD) 653 x442 x139mm
Weight Product Weight 5.6Kg
Shipment Weight 7.2Kg
Stand Function Simple
Type Tilt
crossbow
That's a difficult one to call, but I'd go for the Samsung. This is just a gut-feeling, based on the assumption that Samsung generally make better quality stuff & usually offer better support.
Hunter Duck
Hey Snverhallen,
Which monitor did you buy and are you satisfied with your choice? I'm looking at the same monitors, and also for a PS3 slim. Therefore I want it for the same reason as you do.
Thanks.
Greetings,
Duck
Oculus Quest 2 VR headset + Rotel A14 MkII Amp Reviews & Best of the Month
