Acer CR 8530 8mp Digital Camera £140
Discussion in 'Photography Forums' started by dts borg, Aug 6, 2005.
  1. dts borg
    dts borg
    Sep 5, 2001
    577
    Hornchurch
    +8
    Anyone know if this camera is any good ? :rolleyes: Sounds good for a 8Mp camera but then i KNOW NOTHING :confused: EBuyer
    Image Sensor Type CCD
    Resolution 8.28 Megapixel
    Optical Zoom 3x
    Camera Type Compact
    Interchangeable Lens Without Interchangeable Lens
    Optical Zoom 3x
    35mm Zoom Lens 36 - 108 mm
    Digital Zoom 5.1x
    Focus Type Autofocus
    Focal Length 7.5 - 22.5 mm
    Video Resolutions 640 x 480 (VGA)
    Video Speed 30 fps
    Video Format AVI
    ISO Speeds Auto • 50 • 100 • 200
    Aperture Range f2.8/f4.8 (w/t)
    Shutter Speed 1/2 - 1/1500 sec
    White Balance Manual • Daylight / Sunny (Preset) • Cloudy (Preset) • Fluorescent (Preset) • Tungsten (Preset)
    Memory Type SD Card
    Compression Type JPEG
    Flash Type Built-In
    Flash Functions Flash Off • Auto Flash • Fill-in Flash • Red-eye Reduction Flash
    Viewfinder Optical
    LCD Panel With LCD Panel
    LCD Panel Size 2.5 in.
    LCD Screen Resolution 201,096 pixels
    LCD Protected Position Without LCD Protected Position
    Interface USB 2.0
    Video Interface Video Out
    Battery Type Proprietary Lithium
    Built-in Microphone With Built-in Microphone
    Width 3.58 in.
    Depth 1.06 in.
    Height 2.24 in.
    Weight 0.33 lb.
  2. mr jones
    mr jones
    Oct 23, 2004
    1,041
    41
    (S)cumbria, UK
    +22
    go for less megapixels and a better known brand, you'll more than likely end up with a better camera that feels better and lasts longer.
    8mp for £140, sounds like a cheapo aldi special to me!
    *disclaimer* i dont know about this camera, therefore what im saying is based solely on the fact that megapixels aint everything, and that to put an 8mp CCD in a camera for £140 sacrifices MUST have been made along the way
  3. RobertP
    RobertP
    Nov 21, 2002
    522
    19
    Woodford Essex
    bad quality experience here
    and talk of it being slow and with a poor lens here
  4. dts borg
    dts borg
    Sep 5, 2001
    577
    Hornchurch
    +8
    :eek: Thanks for the help I will look at something else :smashin:
  5. Big-Toe-T
    Big-Toe-T
    Jul 26, 2005
    64
    +3
    it is rebranded different in the big one catalogue Hitachi HDC-831E 8MP for £279.99
