acer cleaning
Discussion in 'LCD & LED LCD TVs' started by sgindin, Jan 8, 2005.
  1. sgindin
    sgindin
    Help! I accidently wrote a line across part of my screen with a red permanent magic marker. Can this be cleaned without destroying the screen? How? (doesn't just wipe off)..
  2. Ultim8Fury
    Ultim8Fury
    to get permenant marker off a white board you should draw over the marking with non-permenant marker as it contains some kind of extra solvent which allows you to wipe it off.
    Getting it off a monitor however is not something I've ever tried and would be very wary of doing. Solvents on screens is not a good thing. If you really can't get the pen off, I would try the above method but entirely at your own risk. I don't want to be the one to take the blame if it goes wrong or melts your screen. Hope this helps you.
  3. njiri
    njiri
    Oct 26, 2002
    149
    19
    UK
    If you can get hold of some ethanol ( needs to be stronger than vodka they sell in shops), try that, as it's relatively benign as a solvent. Isopropanol is quite good too, but difficult to obtain. do NOT use acetone (nail varnish remover), chloroform, or ether. With ethanol or isopropanol, try a bit on a small part of the screen.
    This is my advice only, of course anything you do decide to try is at your own risk.
