ACER AT3201W 32" - HDMI or not?
Discussion in 'LCD & LED LCD TVs Forum' started by varez, Aug 11, 2005.
Tags:
  1. varez
    varez
    Aug 2, 2005
    82
    +6
    Just got this screen and I love it - looking forward to connect a ps3 once it comes out :thumbsup: That is until I realised that the ps3 most likely will only support HDMI - and as far as I know this lcd only supports DVI/HDCP.
    At least it's mentioned in this review: http://www.avforums.com/forums/showthread.php?t=224816
    Then again - a bit of hope, in another thread, HDMI seems to be included with the AT3201W:
    http://www.avforums.com/forums/showthread.php?t=176212&highlight=AT3201W+hdmi
    Can anyone tell me whether or not it supports HDMI?
  2. Barzo
    Barzo
    May 10, 2004
    1,700
    Liverpool
    +473
    It supports HDCP (essential for proposed HD content), but not on HDMI but DVI. Main difference between the two, apart from physical size, is that HDMI transmits a video signal plus audio, whereas DVI only transmits video. Not to worry - the video signal is the same. All you need is a DVI cable, or a converter (HDMI-DVI) if you have a source with HDMI.
    I'd also suggest you look at the review thread again if you are thinking of purchasing this set, as it's been updated over the last two days.
  3. vipergrm
    vipergrm
    Sep 6, 2005
    3,796
    Belfast
    +578
    Just in case you haven't found out yet, apparently you can get a DVI to HDMI adaptor, so it shouldn't be a problem. I have just bought this TV too due to the reviews on this forum. How good is it???
