Acer AL2671W with HDCP
Discussion in 'LCD & LED LCD TVs Forum' started by alfmunich, Mar 23, 2005.
Tags:
  1. alfmunich
    alfmunich
    I've asked if this TV is compatible with HDCP tecnology and I have got this answer from ACER Spain:
    I/O Functions
    .. Connector Type:
    (1) 21 pin Euro-SCART ( RGB ) for Video, S-Video, R.G.B. and Audio
    (2) 21 pin Euro-SCART ( YUV/RGB ) for Video, S-Video, YPbPr, YCbCr and
    Audio
    (3) RCA jack for Video and Audio 3
    (4) 15 pin D-Sub
    (5) 24 pin DVD/HDCP
    .. TV input: DIN45325 ( IEC169-2 ) Terminal
    .. Audio input : Earphone jack
    .. Audio output : Earphone jack
    i hope this information be useful because i've seen many people asking about this topic.
  2. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    Equally as important, what resolutions and refresh rates does it support?
    For Europe HD support, 720p50 and 1080i50(25) are the important ones. Quite a few displays will only support 60Hz which is not much use unless you want to watch NTSC material or can frame rate convert without introducing judder.
    -Ian
  3. JackFlash
    JackFlash
    Errrr.
    Clear as mud then!
    Speak to Acer UK and they will confirm to you that the DVI port is HDCP compliant and the TV is capable of displaying both 720p and 1080i signals. So yes, this product is HDTV-ready.
    Jack
