Acer AL2671W + Progressive Scan + I don't have a clue
Discussion in 'LCD & LED LCD TVs Forum' started by [email protected]_UK, Jul 29, 2005.
Tags:
  1. M@tt_UK
    Should the Acer AL2671W be able to handle Progressive Scan?
    I'm using a Limit DVDA900SE DVD Player with it and I don't get a picture when going into Progressive Scan mode Via the component.
    Thanks very much for any advise.
  2. SteveW70
    SteveW70
  3. M@tt_UK
  4. SteveW70
    SteveW70
    mmmm... I know that there's a bit of a mystery and an ongoing debate whether a component signal can be sent on Scart.
    I'll be honest I'm not sure of an answer. :rolleyes:
    I'm sure the more technical guys on here will have an explanation.
    Seems strange that you're getting a picture in normal component mode :confused:
  5. M@tt_UK
    Thanks for your in-put Steve
    I have solved this now :)
    I needed to keep looking for in-puts after changing to Progressive :D
