Acer AL2671W 26" DVI Refresh Rate ?
Discussion in 'LCD & LED LCD TVs Forum' started by nvrsbr, Sep 22, 2005.
Tags:
  1. nvrsbr
    nvrsbr
    Aug 30, 2005
    17
    4
    Calgary
    Acer AL2671W 26" Widescreen LCD
    Anyone know what the max Refresh Rate is when connected to a PC from DVI out on the video Card to DVI in on the TV?
  2. nvrsbr
    nvrsbr
    Aug 30, 2005
    17
    4
    Calgary
    Anyone ?
  3. peahead
    peahead
    Dec 14, 2002
    2,996
    St.helens
    +384
  4. c00ldown
    c00ldown
  5. peahead
    peahead
    Dec 14, 2002
    2,996
    St.helens
    +384
    refresh rate and response time are to separate things mate.
  6. nvrsbr
    nvrsbr
    Aug 30, 2005
    17
    4
    Calgary
    thanks peahead :clap:
  7. RockySpieler
    RockySpieler
    May 23, 2005
    1,661
    Snaking the Lineup
    +115
    Probably 60hz at 720x1280 or 768x1366, you might have 75hz at 600x800, but you can find out by using the MONINFO ultility. It is written by the same guys who do Powerstrip, which is a very useful utility if your LCD does do 1:1 pixel mapping "out of the box".
    Providing you connect via DVI it should read your EDID values which list the supported resolutions.
    http://www.entechtaiwan.net/util/moninfo.shtm
