ACER 5750 vS 5742 vs 5552 for around £400
UrbanBumpkin
I've finally got my choice of laptops down to 3 (I think) all around £400ish.
ACER Aspire 5750 4GB Core i3 Laptop - Black at cheap prices | PC World
ACER Aspire 5742 Core i3 Laptop in Black LX.R4F02.380 - Acer Direct
Acer Aspire 5552 Windows 7 Laptop LX.R4402.128 - Acer Direct
Which of these is my best option for a laptop not to be used for gaming.
The 5552 has larger hard drive, but a smaller RAM. Also I don't know what the AMD Phenom II N930 is like compared to i3.
I may be able to push the budget a bit more if there's something significantly better. Any suggestions on which one or others is the best option.
What is your budget? £350-£450
What size laptop do you want?
Standard laptops are usually 14" to 16"
Do you have resolution requirements?
No
Do you want a matte or glossy (reflective) screen?
Not bothered either way
What will you be using the laptop for?
internet browsing, downloading music, playing You tube, Video's, the odd spreadsheet / word doc and that's about it.
If you will be gaming, what games do you need to play?
I won't be using it for gaming
How long does the battery need to last?
It will be mainly used at home, so no real need for a long battery life
Does it need to be portable?
Just leaving it at home on a desk
Do you require Blu-Ray?
Not essential
Do you require HDMI output?
I don't think so
Do you have a preferred brand?
I currently have an Acer, quite like them but am open up to other options.
Are there brands you would prefer to avoid?
No
Would you be happy with a refurbished laptop?
Ideally after new, but wouldn't rule out refurbished laptops
Clive
dc8900
I'd get the 5750 hands down, it features the new core i Sandy Bridge, while the the 5742 is the older Arrandale core i cpu series and has the Intel HD 3000 integrated graphics which are much faster than the older Intel HD graphics
Michael
If you go to the Dell Outlet, you can get a refurbished Core i3 15" for £300.
If you want something higher end, with a possibility of gaming, the XPS ones start at £400.
Also, dc, that is just creepy: no replies for 3 hours, then you ninja me by 30 seconds :D
jagr
Acer 5750
dc8900
Don't worry Michael, one day you too will learn the way of the Ninja ;)
But yeah if you the time like Michael says go to the Dell Outlet at around 3.15pm
