Acer 32" LCD TV - AT3201W-A
Discussion in 'LCD & LED LCD TVs Forum' started by shaddow2005, Apr 7, 2005.
Tags:
  1. shaddow2005
    shaddow2005
    Mar 23, 2005
    204
    Just spotted this review at Trusted Reviews.com
    http://www.trustedreviews.com/article.aspx?head=18&page=2777
    Available at Micro Direct
    http://www.microdirect.co.uk/ProductInfo.aspx?ProductID=8935&GroupID=0
    What do we think people ?
    I've been considering the Relisys 3200 as it seems one of the only screens that allows the native resolution with PC.
    This screen looks like a possible alternative but the review mentions a problem with with the screen was trying to scale a 1360x768 PC input upto 1366x768 = seems a bit daft if you ask me.. I wonder if you can turn it off and just have 6 unused pixel lines ?
  2. la gran siete
    la gran siete
    Oct 5, 2003
    25,253
    West Sussex
    +1,977
    Damned sight better value than a philips 9986 Go for it I say.
  3. alunj
    alunj
    Jan 26, 2005
    57
    +3
    i read on one usa site (lcdtv reviews and power strip)
    The reason you cannot do 1366 is that MOSt windows drivers have to do horizontal resolutions in steps of 8 pixels so 1360 1368 (both divisable by 8)
    The same artical mentions that the matrox P650 will do 1366 and some guy reported a big improvement in text readability at 1366 native (open note pad and fill it with either 'mmmmmmmmmmmmmmm' or 'lllllllllllll' as this gives a good test pattern. You should see no variation in the with of the chars across the screen. At 1360/8 you will as the display has to scale again.
    I have the Goodmans LCD32 which uses the same LG panel as the above AFAIK. I guess the only difference is the controller that acer have bolted in behind the panel.
  4. shaddow2005
    shaddow2005
    Mar 23, 2005
    204
    Seems daft, that If most PC's are gonna have touble doing 1366 and have to settle for 1360 that this panel decides to try and upscale it to the correct value.
    Better to just have 6 blank lines of pixels (I'm sure thats what other screens do) - can this be turned off ?
