Acer 113 flicker on Eco mode
Discussion in 'Projectors, Screens & Video Processors' started by KoThreads, Jul 25, 2005.
  1. KoThreads
    KoThreads
    Jan 18, 2005
    3,017
    +183
    It's 7 months old and has only been used for 131 hours bulb life, but yesterday the picture was flickering. I thought it was just the resync that was needed but it never cured it.
    After that I went to it's Acer start up screen and it was flickering badly. then I put it to normal, 1600L mode and the flickering stopped.
    After a bit of trial and error it looks at though when it is in ECO mode, 1200L, the projector is changing itself from Eco to Normal brightness at a fast rate all by itself.
    It starts doing it after it's been on for around 40 minutes in Eco mode.
    IDo
  2. KoThreads
    KoThreads
    Jan 18, 2005
    3,017
    +183
    Could it be the bulb or a mains problem?
    Anyone with any pj had this problem?
  3. KoThreads
    KoThreads
    Jan 18, 2005
    3,017
    +183
    Just connected my UPS to it and the flickering has stopped :confused:
