Accoustic Energy Sub.
Discussion in 'Cables & Switches' started by madcyril, Apr 18, 2005.
  1. madcyril
    madcyril
    May 30, 2004
    1,026
    Manchester
    +94
    I finally received my Evo B 5.1 set up(nearly 3 months).
    Any advice on a decent sub cable,the sub having 2 rca's.Will a rca to rca do the job or will I need 'Y' sub cable.Is there a big difference between the two. :lease:
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    RCA to RCA will be just fine. I would recommend making your own if you can find the hot end of a soldering iron. Alternatively Mark Grant sells some excellent sub cables in the Power Buys section for a reasonable price or check out some of the forum sponsors such as TVCables.co.uk. :)
  3. madcyril
    madcyril
    May 30, 2004
    1,026
    Manchester
    +94
    A 5M Ixos Gamma £27 at TvCables or Mark Grant at £41,will I see a difference apart from £14 missing from my pocket.
