Accoustic Energy AEGO 5.1 Sub - It hums..
Discussion in 'Subwoofers' started by nicky111, Dec 31, 2006.
  1. nicky111
    nicky111
    Hey all,
    I have AE AEGO 5.1 speaker setup - the sub is always making a humming noise when power is on?- is this normal? Im thinking my Denon1730 amp maybe faulty? Anyone have similar problem?
    Thanks:) ,N
  2. AndySee
    AndySee
    Aug 25, 2003
    132
    +6
    i get the same from my Kef PSW2000. My research turned up lots of potential issues.
    Ground loop was one, where your equipment may have more then one route to ground. The theory is that you only want one piece of your equipment to feed earth. One or two reports thought that removing the earth wire from some equipment may be dangerous. I tried removing the earth form the plu, and attempted a wire link between the subwoofer casing and the amp casing. Neither of these worked for me.
    Mains filter cleaning did not get any votes for solving hum.
    I will be contacting Kef next week, as i also found reports of poor amp unit in the subwoofer, so it may need a replacement (not under warranty any more though).
    Sorry I can't remember the most useful links, many were full of the science, and many were buried in archive threads.
    so, not any real answers, but just some shared experience.
  3. sapper44
    sapper44
    Feb 12, 2004
    551
    uk
    +64
    I have the same set of speakers as you.Don't get any humming from my sub.
  4. micaab
    micaab
    Apr 15, 2005
    174
    London
    +11
  5. AndySee
    AndySee
    Aug 25, 2003
    132
    +6
    rang kef today, a very nice man confirmed my problem was a fault in the unit, basically, not ground loop as it still hums when only plugged into mains supply.
    I'm sending it off to them for a refit, £50 including postage and upgraded parts will give me a much improved unit.
    give REL a call.
  6. flushingmeadows
    flushingmeadows
    Dec 5, 2006
    190
    Midlands
    +13
    I have the same AE set of speakers and upon initial install my SW was humming too, drove me mad.
    Tried various things to solve including 2 different SW cables (both good quality), problem still existed, until.... I tried a Mark Grant SW cable, the second I plugged it in the humming went, so happy! :clap:
    If you search for Mark Grant cables on this forum you will see how popular they are. Go to http://www.markgrantcables.co.uk/
    I can't guaruntee it will solve your problem but it did mine!
  7. Ollie20964
    Ollie20964
    Dec 5, 2006
    211
    28
    +30
    Mines exactly the same, hums when set at about half. I've turned it down to a quarter and turned the DB's up on my receiver. Seems to have helped a bit
