accessing panny 5 service menu
Discussion in 'Plasma TVs Forum' started by allanrose, Dec 26, 2002.
  1. allanrose
    allanrose
    Dec 14, 2002
    38
    followed the thread - tried the key presses .......vol (-) + 3xstatus button......but nothing happens! Infact non of the buttons on the front of the unit work which is probably why! I have the unit connected to the panny tuner - is this why?
    Further, the menu's which come up when pressing 'setup' say is nothing like the one shown in the screen's manual but is the one shown in the tuner's manual (Is this normal and is there a way of accessing the former again?)
    all I'm trying to do is check the resolution being received from my denon 2800II dvd - to see if I'm getting progressive pal or not - you'll see this on other threads I've posted
    I'd appreciate you're help, thanks in anticipation!
    Cheers!
  2. allanrose
    allanrose
    Dec 14, 2002
    38
    pressing channel (-) on the tuner box and status button x1 brings up the service menu.....well actually a 'status' or self test report, where you can't actually access anything
    BUT it seems to enable extra reports when you select the status button - in particular a comment that I have '16:9 progressive input' when I select AV4C.......which is the confirmation I was looking for!
  3. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    Yes this is really useful! Thanks. Although it does seem to reset the tuner to factory settings so beware. But the extra info is fantastic.
    Neil.
  4. GlynH
    GlynH
    Dec 9, 2002
    320
    +20
    Are you saying that just by going into the service mode menu and coming out (without changing anything) that when you press the status button it gives extra info (such as incoming scan rate etc.)
    Is this a permanent setting - ie. does it last even after the display is switched off and then back on again?
    Dies it work for every input?
    What other info does it actually give?
    Is this just with the Panasonic tuner box connected or will it work just on the display itself?
    Thanks & regards,
    -=Glyn=-
  5. allanrose
    allanrose
    Dec 14, 2002
    38
    yes...but you only get the comment '16:9 progressive input' when you select AV4C
    yes
    yes but you don't appear to get any extra info
    none
    dunno, I only have the tuner box as an input
