Access V+ settings via reset button
Supra_ed
Hi all,
I know there is a way of getting into the settings of the V+ box using the reset button and holding down another button, does anyone know what buttons need to be pressed? I've lost my picture signal somehow, its not on HDMI or SCART :mad: Muppet.
Cheers.
cdh555
You may have changed it over to component but you can choose the output during a reboot as follows:
Hold in the Stop and Play/Pause buttons on the front panel, and press Reset.
Keep Stop and Play/Pause held in until the display says 'boot'.
After a few seconds the display should say 'outpt'. Press the Fast Forward button several times until the display says 'Sd' (might also show Scart, so choose your output), then press OK.
Wait for the V+ to reboot.
Then hook up over scart and set it up in the settings as normal for what you want.
