DanH23
Looking for some advice before I purchase a router to be used as an access point.
I'm running a length of cat6 cable to an outbuilding where I want to have both a wired and wireless connection.
I have seen the following on Amazon which is discounted and has both gigabit ethernet ports and dual band WiFi. It can also be used as an AP.
Would this work for what I need and would I still have the use of the ethernet ports even if in access point mode?
I read online about needing to have it set up so that it isn't doing anything with NAT and DHCP. Would there be a few settings that I needed to change before using?
Deal: TP-Link AC1200 Wireless Dual Band Full Gigabit Wi-Fi Router, Wi-Fi Speed Up to 867 Mbps/5 GHz + 300 Mbps/2.4 GHz, 4+1 Gigabit Ports, Dual-Core CPU, Parental Control, Easy setup (Archer C6 V3.2) Amazon product
