Accent Htpc Case / Dign Cooling Advice Needed
Discussion in 'Desktop & Laptop Computers Forum' started by zypheruk, May 9, 2003.
  1. zypheruk
    zypheruk
    Hi all, looking some advice on cooling a Acccent HTPC case formerly DIGN, heres whats in my case:
    msi kt400 8x agp mb
    xp2.2 gig cpu
    1 gig pc333 ddr ram
    msi geforce4 ti4200 8xagp
    hauppage nexus-s dvb satellite card
    pioneer ao5 dvd burner
    16x dvd rom drive
    2 x maxtor 120gig hds
    Now bare in mind this pc needs to be near silient nothing worse than listening to noisy fans during a quite scene in a movie, and most importantly cool.
    Im thinking of a Copper Thermalright SLK-900 if it fits on the m/b, with large papst fan and 1x front papst 8cm intake fan, and 2 x 6cm for the rear but dont no which make for the rear. GFX im thinking of removing the fan and replacing it with a Zalman vga cooler, will it b enough to cool the card. And I also want to remove the northbridge fan and replace with a large heatsink.
    So if anyone has tried this, any feedback would be great I dont want to waste alot of money on cooling if it dont work.
    Thanks folks
  2. Rob.Screene
    Rob.Screene
    Sep 29, 2001
    1,282
    Berks, England
    +131
    I put a Zalman chipset cooler on my KT266A desktop board. The temperature actually went down.
    I'm about to put the Zalman 300W psu in my Dign case, when Amtrack manage to find us in. Mind you, a Radeon DDR, 40GB 5400rpm drive, 25GB 5400rpm drive and 2GHz P4 are probably going to generate only about 60% of the heat of the setup you mention.
    regards,
    Rob.
  3. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    I've got a heatpipe cooler on my GF4 Ti4400 and it says cool.
