Accent HT400 - Do I have to use iMon?
Discussion in 'Desktop & Laptop Computers Forum' started by wyerd, Jun 25, 2004.
  1. wyerd
    wyerd
    Dec 29, 2000
    758
    28
    Upstate New York. USA
    +27
    I would like to use the USBUIRT instead of the supplied iMon. I’ve wired the power/reset, HDD busy & power light cables to the motherboard, but the LED’s are not lighting up. Is this because they need power from the iMon power cable? Is it possible for them to work without?
  2. X-Factor
    X-Factor
    Nov 1, 2003
    57
    Scotland
    I wouldn't have though the LED's would require the extra cable, I'm building my PC tonight So I'll try it with and without the cable and see what happens.
    Does the USBUIRT allow you to power up/down the PC I thought this was a special feature of the accent/imon PCB?
    Did you have any problems fitting the PSU, read the review on HTPCnews but not quite sure what the reviewer was trying to get over about the PSU.
  3. wyerd
    wyerd
    Dec 29, 2000
    758
    28
    +27
    I'm leaving the system 24x7, so I'm not worried about this feature.
    I fitted the SilenX 400W without any problems. The power cables come out from the bottom when it's fitted, so it's a bit tight.
  4. Rolling
    Rolling
    Nov 20, 2001
    341
    England
    +27
    Hi...Does anyone no where to buy the imon in the uk.....cheers
  5. wyerd
    wyerd
    Dec 29, 2000
    758
    28
    +27
    Try QuietPC.com
  6. stevieboyyyy
    stevieboyyyy
    Jun 21, 2004
    71
    Hampshire
    +6
    Silly question, is the polarity of the cables correct?
  7. wyerd
    wyerd
    Dec 29, 2000
    758
    28
    +27
    Err..... yes it was! There weren't any instructions on how to put the case together - only the Imon, (my excuse anyway)
  8. stevieboyyyy
    stevieboyyyy
    Jun 21, 2004
    71
    Hampshire
    +6
    I put mine together backwards :blush: and you're right, the only instructions come with the IMON and don't cover this. I'm assuming the PCB is a special one just for the HT-400. Just looking at the IMON for the first time this weekend, seems to be okay but buttons are limited.
