AC3/Dolby Digital Any technical difference?
Discussion in 'AV Receivers & Amplifiers' started by andy76, Nov 20, 2003.
  1. andy76
    andy76
    Are there any technical differences between the two in terms of decoding?
    Should a modern Dolby Digital amp decode AC3 laserdiscs OK?
    Andrew
  2. FlimsyFeet
    FlimsyFeet
    Oct 18, 2003
    91
    No difference, they are the same thing - AC3 is the name of the compression algorithm used for Dolby Digital soundtracks.
  3. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +13
    AC3 is just Dolby's 3rd generation audio compression (hence AC3).
  4. Dutch
    Dutch
    Dec 5, 2002
    2,597
    3
    North Yorkshire
    +282
    Andy,
    Please be aware that you need a Laserdisc specific AC-3 input on your amp as the signal has to be de-modulated - you can't use a normal coax input used for DVD/CD. Not many amps have these inputs unfortunately. Hope this helps.
    Steve
  5. chrisgeary
    chrisgeary
    Jul 23, 2003
    2,505
    Newbury
    +175
    The Yamaha A3090 has that input.. I might be selling it soon, if you were interested? It can also decode mainstream DVDs as you would expect.
