MontyPS3
Hi Folks,
Prob a really daft question but which is better at recycling the air within a flat? opening the windows or using the air conditioning.
It a corner flat - so no opposite ended windows - instead it's like windows on the two perpendicular sides of a square.
And it's a central AC as well so not just in one room.
Quick answer as I'm cleaning my flat now and it stinks like a chemical factory!!
