ac power cable
Discussion in 'Cables & Switches' started by oldguy, Mar 29, 2005.
  1. oldguy
    oldguy
    Feb 21, 2005
    42
    rotherham
    Anyone know if it's possible to get hold of / make up a long ac power cable ?
    It's for my LCD tv, the one supplied is only 5 foot and i'd like one much longer but can't find the End Connector (the two hole flat female type found on most domestic appliances ). The connector is moulded onto the cable, and i don't really want to cut and jion the cable, i'd prefer one long cable as it's going behind a wall then under the floor and i'll not ne able to get to it if there was ever a problem with the joint
    thanks
  2. Peridot
    Peridot
    Aug 24, 2004
    2,979
    Newport, South Wales
    +293
    The 'figure 8' connector is available from Maplins. See here.
    Does need to be soldered though.
    _______________
    Dermot
