chrisgeary
Is it possible to buy a really small, silent mini split (or possibly ducted) for a 3.3 x 2.6m room? I currently have a Daikin FXTS25k installed and its way too powerful for the room. I guess I'm looking for something that is around 5000btu with inverter so it can run even lower than that.
For evening movie watching during the summer months, even with the Daikin on whisper fan mode, 22c set point (at which point its consuming 140w of power which is as low as it will go), the room gets cold quickly, then it turns off the compressor so we get loads of humidity. I'm currently using a Tado Smart AC to do the temperature regulation which avoids the humidity dumping. Even during the heat of the recent warm days, whisper fan mode is enough to keep the room cool with it running constantly.
I can't seem to find any split systems lower than 9000btu. Anyone know of a super small quiet split system that might fit my small room needs?
