About to purchase; last minute advice...
Discussion in 'Plasma TVs Forum' started by Phybron, Sep 9, 2004.
  1. Phybron
    Phybron
    Ok I'm about to order either a Sharp LC22AD1e or a Samsung LW22A13WX.
    I was set on the Sharp, but I've realised the Samsung sounds slightly better on paper at least:
    Sharp resolution is 845x480 | Samsung is 1280 x 720
    Sharp brightness is 430cd/m2 | Samsung is 450cd/m2
    Sharp contrast is 500:1 | Samsung is 600:1
    Sharp speakers are 2x5W | Samsung is 2x7W
    Sharp has no PC input | Samsung does
    Sharp has freeview built in | Samsung doesn't, but I have separate box anyway
    Sharp is £960 | Samsung is £790
    I buying primarily for playing consoles. Any suggestions or advice would be appreciated, or I'm going for the Samsung.
  2. richard plumb
    richard plumb
    Jan 27, 2002
    14,477
    Windsor
    +1,046
    Go for the samsung. The new Sharps are using low res panels and aren't getting the rave reviews their previous generation got. Maybe resting on their laurels?
    For a console freak, hi res panels are a good thing. Especially if you mod your xbox and can output 720p - perfect match for the samsung. (does it have component in?)
  3. Phybron
    Phybron
    That's the only downside I can see - it doesn't have component in - but neither does the Sharp. It does have DVI-I though, which you can mod an Xbox to do can't you?
  4. Phybron
    Phybron
    Gone for the Samsung. Hope it's good.
