About to buy pw7-this ok?
Discussion in 'Plasma TVs Forum' started by myszka, Mar 16, 2005.
  1. myszka
    myszka
    I have deliberated long and hard but now seem ready to make the investment.Though that 26in Sonix in the lcd forum seems very tempting.
    The Panny comes with a scart board.I have a humax pvr with 2 scarts.I will have a pioneer 575a tomorrow.
    I presume i connect the freeview to the Panny,and then the dvd to the Humax,which has rgb in and out via scart and the optical out or coaxial from the dvd to my receiver.Is this correct?I do get confused about it all.One of the reasons why the Sonix looks so tempting.
    Bob
  2. andyAV
    andyAV
    Bob
    Looks correct - but just in case you're not aware, you will need PVR to Receiver too - probably twin phono.
    Also for the panny screens there is comment that scart isn't the best piccy. If it turns out too soft for your liking you can almost certainly improve things by buying a RGB-VGA converter and running the scart from the PVR to that and the vga cable from that to the screen. Search this forum for suggestions (I've got JS tech version but there are others). The JS one will set you back about £150 + cable but piccy is very good (comparable to component IMHO from my Tosh 220 DVD).
    Enjoy.
    Andy
  3. myszka
    myszka
    Andy
    Thanks for the reply.
    The scart board comes "free" with Panny so i will try that and then look out for a second hand js box and sell the scart board :) Just missed one by minutes on the forum yesterday :(
    I have lots of spare phono cables so will try your suggestion.
    cheers
  4. GCDB
    GCDB
    Sep 23, 2004
    321
    Wrexham
    hi,
    could be wrong,but not sure if my humax 8000 pvr has rgb pass through?It does have twin scarts but thought only one was rgb.I am sure i will be proved wrong very soon.........
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    also suggest you source a component input for DVD when funds/time allow.........I think the Humax is RGB passthrough,
  6. myszka
    myszka
    Do you mean a component board to fit in the Panny?
    If so then i will.
    I am sure the Humax is rgb passthrough.If not any suggestions?
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
  8. myszka
    myszka
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    I owned one for a week, i think it did do pass through (may have only been Composite can remember)
  10. bobinski
    bobinski
    Feb 13, 2005
    647
    london
    +13
    Ok.
    Proof will be in the pudding next week :)
    Bob
