About to buy a Pioneer 656 - still the best for the money (340)? also....
Discussion in 'Blu-ray & DVD Players & Recorders' started by PapAV, Mar 18, 2003.
  1. PapAV
    PapAV
    May 10, 2002
    187
    +15
    I'm gonna get a QED SQART RGB Scart lead? Still pucka?
    And i was thinking of getting a 30 quid IXOS TOSLINK cable, but I wondered if I'd notice any improvement over a bog standard tenner jobby from comet
    System;
    36" Pixel Plus
    Sony 940 DTS amp
    4 x tannoy mercury floorstanders & matching centre
    2nd Sony amp powering JBL sub.
  2. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    QED AV2110 is brill for the money (I think you can get it from Empire Direcr for £30 + PP).
    Does your amp only have optical in? Otherwise consider QED Qunex P75 coax (£25)
  3. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    the QED AV41 RGB-only Squart is, at £50, not worth the money IMO. I actually prefer the picture from my £20 cinemax scart
    the pioneer 656 is a fantastic player but I think you should be able to find it cheaper than £340
  4. juboy
    juboy
    Definitely go with a coaxial cable if you're able to and the length needed is less than about 5 metres.
    My personal choice would be to save a few quid over the QED and go for the Ecosse 'The Producer' coax cable at £19. A better cable IMO and cheaper too.
  5. PapAV
    PapAV
    May 10, 2002
    187
    +15
    I thought the COAX digital cables suffered from interference where optical didn't.
    Which is better and why?
  6. juboy
    juboy
    Under 5meters a decent, screened coax cable shouldn't suffer from interference and is likely to give a slightly better sound, technically.
    TBH, whether or not you'd actually hear the difference is another question but you may as well get the best tool for the job anyway.
  7. James45
    James45
    Sep 21, 2002
    2,844
    59
    and coax cables are more robust as well
  8. juboy
    juboy
    Good point.
  9. dogastus
    dogastus
    Jan 24, 2003
    204
    Newbury, England
    +5
    you can get the Pioneer 656 for £320 from AVLAND
    Nigel
  10. LDR
    LDR
    Apr 1, 2002
    2,297
    Wales
    +98
    Or £299 from LE Concepts. :smashin:
  11. jem
    jem
    Sep 24, 2002
    527
    +7
    Avland and HiFi junkies have no stock and don't expect any for a couple of weeks at least - or so I was told at the end of last week.
    LE Concepts had stock at the end of last week for £309.99 delivered.
