about position??
Discussion in 'Subwoofers' started by hurling, Jun 18, 2004.
  1. hurling
    hurling
    can anyone tell me the best position for a sub??? directly in front? on the ground? thanks
  2. Zone
    Zone
    Jun 24, 2001
    6,747
    Barnsley
    +2,441
    Mine sits in between the front left and right speakers, for aesthetics as well as being convenient.
    I know it’s not the ideal position for my sub in my room, but to be honest I’m a lazy sod and can’t be bothered to experiment and move it.
    Another principle people try is placing the sub in the listening position (the position where you yourself would normally sit) and then using a SPL meter and a test disc take measurements from different possible subwoofer positions and see which one gives the best response, then put the sub there, its easier on the back than humping a sub around the room.
    Bottom line trial and error, unless you’re me of course ;)
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,423
    Somewhere in South Yorkshire
    +5,823
    No straight answer except........where it sounds best in your room. Too many variables with room acoustics, nature of furnishings and wallcoverings etc etc. Experiment.
  4. hurling
    hurling
    thanks for the advice lads! i think the meter sounds like the best option.
