About blank
Discussion in 'Desktop & Laptop Computers Forum' started by Taz, May 30, 2004.
  1. Taz
    Taz
    Guys....
    Im using IE6 (not a new install I've had it a while on XP pro) for some reason nearly every link I click on I get the page no worries but I also get a small window that pops up named "about:blank -Microsoft..." Any ideas what's causing this??
    TIA
  2. Taz
    Taz
    No one :confused:
  3. iansimpson888
    iansimpson888
    Aug 17, 2003
    364
    46
    Standish
    +173
    I assume you've ran anti virus / spyware etc...
    Is the page blank? Have you maximized it to check? Once it's open goto View >> Source, open in notepad. Should display html /html if it's blank.
    Check in Internet settings >> Advanced >> Reuse windows for launching shortcuts. Change the setting, apply, close IE. Reopen, test. Change setting back, apply, close IE.
    Check the version details of iexplore.exe, reinstall IE6 if need be.
    What is your homepage set to?
  4. Taz
    Taz
    Thanks for that info, I will give it all a try.
    Home page is my Yahoo mail log-in.
