Quantcast
? Abount DENON 3802 remote
H
Hal
mine works fine but only if the back light is off as soon as you turn it on nothing works turn it off and you are back in action. Is this normal as it is some what anoying
ps doint do if any one is intrested but B&Q sell I dimmer switch that is infered for only £22 its a straight swap with the standed switch and you can program the DENON 3802 Amp to control it no prolem so I guss anyone who has learnig remote is in bussnes
T.I.A
Rich
my remote works the amp ok when the backlight is on,but won't work anything else eg TV,Sky.......your right about it
