Abit of help
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by nismo_lfc, May 4, 2007.
  1. nismo_lfc
    nismo_lfc
    Apr 14, 2007
    28
    3
    Are there any mobile phone sized camcorders, I know nokia have a range of phones with ok'ish quality recording, but is there anything the same size(handheld) which exceeds the quality? someone said DV cams or mini DV cams, but I havent been able to find them o_O
    Nismo :thumbsup:
  2. sassan22
    sassan22
    You can't find any DV or miniDV cams that small. I would suggest a digital camera with integrated video function. I have a canon Ixus 800 which is very small and captures video in a descent quality. It captures in mjpeg meaning that you need 1GB for 7 minutes or so, but it is a very good format if you are planning to post edit your clips.
