Abit NF7-s V2 advixe required.
Discussion in 'Desktop & Laptop Computers Forum' started by Pulsar, Nov 29, 2003.
  1. Pulsar
    Pulsar
    Jan 19, 2003
    3,023
    West Midlands - Stourbridge
    +329
    Hello,
    I have been using this great mb for a few months now, and I am very happy. On Tuesday I shall be getting my new DVD-R drive, and I am trying to think of the best way to connect it up.
    At the moment I have all 4 IDE connections used with 2 HD's, a CDRW drive and a DVD ROM drive. If I have to, I will sacrifice my CDRW drive, but that is faster than the CD write speed on teh DVD-R, and I want to have 2 DVD readers for those occasional 2 disc DVD's that you get.
    I have noticed on the mb that there is a serial connection. Also in the mb box, there is a IDE to serial converter. What I need to know is; can I connect the 4 IDE devices and 1 serial device at the same time?
    I hope I have made myself clear, and thanks in advance for your help.
    Rob
  2. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    yes, you can:) be careful if its a maxtor hdd though as they dont tend to mix with the sata adaptor to well:(
  3. Pulsar
    Pulsar
    Jan 19, 2003
    3,023
    +329
    Hi James,
    I hoped it would be you to answer, as I have seen you discuss the NF7-s before. Here are the drives I have:
    -80 GB Seagate Barracuda. This drive has the windown install on.
    -120 GB Seagate Barracuda.
    -LG DVD ROM Drive
    -TDK Cyclone CDRW
    -Soon to have a Sony DVDR
    My priority is to have the 80 HD and the Sony DVDR on the fastest busses.
    What config do you suggest.
    Rob
  4. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    well as far as i know, only hdd's can go on the s-ata controllers. That's not a bad thing though, because the ata-133 controller provides more than enough bandwidth for any drive you are likely to connect.
    To be honest, i dont have much experiance with s-ata because my hdd is a maxtor so i'll be damned if im gonna risk data corruption lol
    The best thing i can suggest is to head over to http://forum.oc-forums.com and ask there. they have a huge abit fanbase there (i'm one of them;) ) and you can be certain you'll get all the info you need there:)
