Abit Il90-mv Hdmi Output??? Help
Discussion in 'Desktop & Laptop Computers Forum' started by Jamcyrix, Apr 22, 2007.
  1. Jamcyrix
    Jamcyrix
    Hello
    I've just built a new Vista Media Centre PC and when connecting it to my 26" Samsung via HDMI-HDMI, I can't seem to get anywhere near a decent resolution. The picture is either too big or way too small.
    Any suggestions guys??
  2. tim_kay
    tim_kay
    We had the exact same problem with this board. There is an F command shortcut which you can hit @ bios POST which switches from vga/hdmi connection, this also if I remember correctly re-scans, and can output @ different res. We found when installing it looked ok, then in O/s it was a tiny box, you need something like powerstrip to then stretch out the image if your display doesnt shake hands correctly, as so to speak. Some dispays will max out and some won't.
  3. Jamcyrix
    Jamcyrix
    Alt-F4 switches between VGA and HDMI, but I've had no luck whatsoever shrinking or stretching the image with Powerstrip - Just keep getting 'Out Of Range'.
  4. rcadey
    rcadey
    Sep 7, 2006
    83
    +6
    what model Samsung are you on?
    if its an LE26??? then the HDMI input is designed to only take a certain range of input resolutions - even those that it is designed to work with it will apply overscan.
    The intel drivers for the abit board don't allow any kind of compensation so you are stuck with an overscanned picture which works okish for Media Center and DVD playing but not for a PC desktop
    you'll get much better results using a pixel mapped VGA output
    rob
  5. Jamcyrix
    Jamcyrix
    Hi Rob
    Yeah, it's an LE26.
    Any advice on "using a pixel mapped VGA output"?
    Jamie
  6. guv69
    guv69
    Sep 20, 2005
    622
    +33
    Eek! That doesnt sound good! I was literally about to place an order for this MB!
    Have you tried the newest driver for it? Most seem to be new in the past 2 weeks!
    How did you get on installing to SATA? Via a floppy or slipstreamed CD? I'm a bit concerned about this as I dont want to start frigging about with floppy drives!
  7. rcadey
    rcadey
    Sep 7, 2006
    83
    +6
    use a VGA cable from the VGA out on the MB to the VGA in on the TV
    select 1360 X 768 output resolution
    if necessary do an auto adjust on the tv (via the TVs PC menu)
    should be as simple as that
    HDMI to HDMI is really for viewing video/TV at the moment not a PC desktop, the TV manufacturers still haven't got their heads around the fact that people might want to connect their PC in this way
    rob
  8. Synchro
    Synchro
    Nov 14, 2004
    6,003
    Chester
    +1,537
    /me agrees. Stear Clear of HDMI output from PC's unless you're prepared to do a lot a testing and sending equipment back for replacements.
  9. tim_kay
    tim_kay
    rcadey you jogged my memory.
    We had the same problem with this board, but eventually found the solution. The 960 GMA drivers that come shipped with the board do not support HDMI to go full screen, we found another set, which was either on Abit forum or Intels site which supported HDMi to high resolutions.
    Sorry I can't be anymore helpful, we found its a great board, but not HDCP compliant for Bluray so stopped development.
    The re-size you mention won't stretch the image either.
  10. rcadey
    rcadey
    Sep 7, 2006
    83
    +6
    tim
    its not the drivers its what the TV does with the signal - unless the TV gets a standard HDMI signal (1280 X 720 or 1920 X 1080) it doesn't really know what to do with it. For the standard def resolutions it overscans because it assumes it is getting a signal from a consumer electronics video device.
    better drivers might be able to fool its processing but you are really fighting a losing battle (scaling in the pc then rescaling on the TV)
    some very new TVs (last 3 months) are starting to give better control (or less control to the TV) but these are few and far between.
    Interesting to hear of your experiences with Blu Ray and HDCP. Abit claim it to be complianthttp://forum.abit-usa.com/showthread.php?t=117247&highlight=hdcp+compliant
    have you found this not to be the case?
    The re-size is for the vga input only and correctly positions the vga output on screen to perfectly pixel map
    rob
  11. tim_kay
    tim_kay
    I would completely agree, however I can confirm that the driver update most definately offered a much large choice of resolutions, include 1280/720, which fits much better than the 800x600 which the user above is experiencing. STrange I know, but 100% confirmed, and yes Abits claims for compliance are fine, however trying to get software to shake hands on the HDCP with the GMA950 is at this point impossible, unless you use Any DVD, of course!
  12. paul_warren
    paul_warren
    Nov 23, 2006
    190
    +15
    I've got this motherboard in my HTPC - and I'm using the VGA connection - luckily my Panasonic TH37PX60 supports 1:1 pixel mapping so the picture for the desktop and videos/tv fits perfectly! :)
