ABIT AU10 + which amp and speakers?
Discussion in 'AV Receivers & Amplifiers' started by jim_herd, Jul 21, 2001.
  1. jim_herd
    jim_herd
    Hi Folks,
    I'm going to be setting up my home cinema over the next few weeks and am just considering what amplifier and speakers to marry with the sound card in my PC.
    Since the card comes with WinDVD2000, and the sound decoding is software based, all I actually need is a 5.1 amplifier and some speakers. I'm not sure exactly how good the quality of the sound will be although reviews have said that it is pretty good although it probably won't match a decent external receiver.
    Naturally, lugging the PC to the shops for a listen is out of the question! So, I'm looking for budget recommendations between £500-1000.
    Cheers,
    JAH
    P.S. If anyone is currently using this card I'd appreciate hearing about your setup and experiences.
    [ 21-07-2001: Message edited by: jah ]
