Aargh! Tag up-grading. Assistance required.
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by Steve.EX, Nov 3, 2003.
  1. Steve.EX
    Steve.EX
    Oct 17, 2001
    3,096
    68
    +69
    When trying to install 4.10 the unit does "it's thing" until it reboots and goes into "up-grading dsp's" at which point i get a field (on up-grade wizard) informing me that there is a loss of power or disconnection of cables.
    I have had to turn the unit off three times now with the "up-grading dsp's" being displayed on screen, although the wizard instructions say to check connections AND disconnect power.
    Have i knackered my unit?
    When i remove programming cables it shows v4.10 on screen but all the menu's are present and settings intact from previous version . I have not the courage to turn on the power-amps just in case.
    Why is this happening?
    regards
    Steven.
  2. mark67
    mark67
    Steve,
    As the great man himself (Udo)would say....contact the helpdesk :eek: .
    Couldn't resist. Seriously, hope you get it sorted.
    We meer mortals are still on the Single Processor:zonked: :zonked: .
  3. cj
    cj
    Apr 6, 2001
    1,457
    Reading
    +74
    Hmmm I just put 4.20 on mine without any problems - have you tried putting 4.9 back on?
  4. cskates
    cskates
    Jul 5, 2001
    151
    Belfast, UK
    Do you have the lastest version of the wizard, 2.22?
    I had the same problem a while ago on my DP and it was solved using the latest wizard. In my case, it eventually worked after trying a few times. The flash process seems pretty robust, an incomplete flash shouldn't knacker things permanently.
  5. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    May also be worth posting this in the Tag Forum here...may get a few more views.
  6. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    It actually has about half the views! Helpdesk and latest wizard seem the best route IMHO. Knowing Steve he will have done both already I suspect.
  7. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    Good idea Beekeeper.....Makes me grateful that I've just left the software etc alone on mine,pending an eventual upgrade to the DP version.
  8. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    I am still unconvinced to part with hard earned money for the DP, poor Steve has had so many problems.
  9. Steve.EX
    Steve.EX
    Oct 17, 2001
    3,096
    68
    +69
    Well, after disconnecting everything, which to be honest i find a chore (the only unused inputs left are composite video!) and carting it up to a friends with a super dooper desk-top, what can i say? We plugged it in and it up-dated first time so whatever the problem is it is clearly linked to my "toy" laptop.
    Tag returned (via e-mail) the PL2x code within 20 minutes, so i now havw PL2x and height-channel (speakers pre-installed).
    I will post my thoughts on both after the weekend when i have had time to accustomise.
    Regards
    Steven
  10. AOD
    AOD
    Feb 7, 2001
    710
    London
    +4
    Steve,
    From memory, Tag say that certain laptops have problems with the Tagtronic cable due to voltage issues with the serial port. :(
    As you found out, using a desktop is perhaps a better option. Having said that, my laptop (an aging Compaq Evo with 98SE) was able to upgrade my AV32R without any issues. I did take the precaution of running it on mains power rather than battery though.
