breadmaker6
Hi All,
Apologies for the noobie question!
I am looking to buy some software for my missus to create beat matched mixes for an aerobics class.
I have found one that seem to do the job simply called Mix Meister Express.
However, over that last 3 years I have spent time importing my songs in standard AAC 128. The probles is it appears that the program doesn't support AAC.
So is there a quick way of creating copies of my AAC files into MP3 etc without having both sets in iTunes and on my Ipod (taking up space).
Or maybe someone knows of another decent program that will do the same thing that does except AAC.
Thank you.
Thank you.
