Just a quick query I was under the impression from RTFM that the DVI input would be retained on the 300xtra HDMI version. BUT...on arrival the DVI input has gone walk abouts. While not a huge issue has knackerd my setup plans alittle. I take it this is the way its supposed to be then?
I think all you need to do is take the DVI out into HDMI on the Extra with a DVI to HDMI cable. Hope this helps.
Here it is Dustin, The 300 Xtra will retain the DVI input and the brightness is still the same at approx 800 ansi. HDMI and DVI are both high quality digital signals. END QUOTE Dosent matter realy, just need a gefen switch box etc, already got a dvi to HDMI adapter, so will go that way. ALL SORTED
What DVD player you driving it with?(A11?) My Gefen DVI switcher is still random switching but otherwise is great, have you heard any update on a fix by any chance?(I need to contact Joe etc) I look forward to you first review!
Hi fulabeer, just done review, at present driving with a pioneer 868i for its HDMI connection A11 was sold couple of mths ago as im saving for the new denon 1X havent orderd switcher yet, just know its what i need.
