aaaghhhh help!!!
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by gasman71, Apr 7, 2005.
  1. gasman71
    gasman71
    I have just installed ulead video studio 8 and done something incredibly stupid.
    I was importing some of my photo's from a memory stick. After loading them up I decided that I would like to edit the images first in adobe photodeluxen.
    Before I edited the photos I thought I would remove them from ulead. In Ulead I selected the images to delete ( as i didn't want the unedited photos in the application) and pressed yes. yes at the notify boxes (without really paying much attention ) However I did not realise that the application actually deletes it from its original location on the memory stick or drive. As you can imagine I am feeling somewhat annoyed
    Does anyone know any way of recovering the files ( I have already cheked in the recycle bin). OK i was a bit stupid but it does annoy me that the application can remove the files from your drive/memory stick. This is not the case on adobe photodeluxe editor
    :oops: :oops:
  2. klr10
    klr10
    Dec 20, 2003
    801
    28
    Sawbridgeworth
    +27
    Try this software -
    http://diskinternals.com/
    I think there are others too if you google for 'recover deleted files'
    Hope this helps
    PS Do not use the memory stick until you have recovered your files or they will be overwritten!!
  3. gasman71
    gasman71
  4. klr10
    klr10
    Dec 20, 2003
    801
    28
    Sawbridgeworth
    +27
    :thumbsup: nice one :D
  5. BadAss
    BadAss
    Feb 2, 2001
    2,967
    England
    +182
    But wont they be in the recycle bin?
  6. duncanmcewan
    duncanmcewan
    Deleting items off a USB "pen" drive removes them ... there is no recycle bin.
    Dunc.
  7. Brian110507
    Brian110507
    Yes - I suspect that although 'gasman' says he was importing his pictures into Ulead VideoStudio he was in fact only linking to his memory stick which only puts thumbnails into videostudio but leaves the pictures on the memory stick.
    Two ways to avoid the problem in future,
    !) - transfer the pictures to the hard drive first - then if you do inadvertantly delete them they will be in the recycle bin.
    2) - Read the dialogue boxes very carefully when deleting in VideoStudio - the first prompt would ask you if you wanted to delete the thumbnail - the second would of asked if you wanted to delete the original file (quoting full path ) - next time say 'NO' to that second question.
