A9G 77" Wall Mount
Hamsnacks
Hello,
Currently have a A9G 77" arriving today and would like to hang it up where the 65" A9F is hung.
I haven't been able to find an answer online but will a regular aftermarket wall mount work on the A9G the same way it would work on the A9F or are you required to use Sony's mount? It seems like the G only has 2 bolts versus the standard 4 bolts.
Thank you in advance!
Thank
MultiRoom
It’s a standard VESA mounting point. Any TV bracket on the market rated for a TV this size will be suitable. I’m using a sanus on my AG9 (77inch).
pastrybloke19
As long as the mount has the required VESA mounts, and is rated for the weight, it will work fine.
Key part is the fixings into the wall - I used 8 on my 55”, defo OTT!
