A90 + P85
Discussion in 'Arcam Owners' Forum' started by Sweden, Apr 24, 2005.
  1. Sweden
    Sweden
    Hi all,
    Can i have a P85 w my A90 ?
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,523
    Edinburgh
    +1,243
    Absolutely, all Arcam amps are gain matched so they will all work together.
  3. Mofar
    Mofar
    Apr 12, 2005
    34
    +4
    @Crustyloafer: all Arcam amps are gain matched, so I can combine my AVR300 with one of the FMJ amps?
  4. ANDY_DUTTON
    ANDY_DUTTON
    Aug 27, 2002
    498
    28
    Cambridge
    +87
    Yes, with the exception of the P7 which being a THX approved amplifer has to be THX gain.
    Regards,
    Andrew
  5. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,523
    Edinburgh
    +1,243
    :thumbsup: Darn, he beat me to it.
  6. mrkeeling
    mrkeeling
    How much difference is there between P85 and P90 (other than 5W of power)?
    I just got P85 (it was more friendly priced than P90), so I am wondering if saving was worth it. :confused: I never had the chance to listen to them side by side.
    :beer:
  7. Vanderlay
    Vanderlay
    Oct 12, 2004
    47
    I've been wondering about the same, because I've heard two difefrent stories.
    1. That P85 was just rebadged and called P90 because it already had the extra power.
    2. Some argue that A90 sound significantly different and not only more powerful than A85. If this is the case, shouldn't P85 and P90 be different from each other?
    In either case, I think you'll be alright with the A90/P85 combo.
  8. dm57
    dm57
    Here is the quote from Mr. Dawson's earlier mail. This goes for P85/3 but I guess the same should be with P85
    You can use a P85/3 or 90/3 - these are electrically identical. We only changed the name to tie up with the change in integrated amps from A85 to the improved A90.
    John Dawson (Arcam)
  9. Sweden
    Sweden
    thanks everyone.
    has someone compared a85 and a90 side by side ?
  10. DistortedVision
    DistortedVision
    Jun 7, 2005
    155
    Cheshire
    I noticed that What Hi Fi Sound & Vision gave the A90 a disappointing 3/5 stars saying it was "Flexible and warm but ultimately, this amplifier sounds anonymous"
    The A85 was raved about and was an Award Winner for two years running (if my memory serves my correctly). Interestingly the P85 received 4/5 but the P90 got 5/5.
  11. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,523
    Edinburgh
    +1,243
    That just goes to show how well magazine reviews can be trusted.
