A90 and P85 :Which one for hi and low ?
Discussion in 'Arcam Owners' Forum' started by Sweden, May 5, 2005.
  1. Sweden
    Sweden
    I have an A90 and P85 which one should i use for highs and which one for lows ?
  2. Crespotav
    Crespotav
    Feb 27, 2005
    49
    Kimpala
    Use the shortest path from the A90 to the Mid/High frequencies. There is where most of the music is, unless you only listen to Kodo Drums. Also less power is drawn in this way, which may matter if you listen to bass-heavy music at high volumes.
    The P85 can use its full power to drive the bass units in your speakers and handle the more difficult loads that some speakers require.
    I do not have the A90 manual at hand, but for the FMJ A22 that is the recommended way.
