A85 v A22
Discussion in 'AV Receivers & Amplifiers' started by witters, Mar 25, 2003.
  1. witters
    witters
    Jul 13, 2000
    12,615
    Yorkshire
    +291
    I may have the opportunity to *upgrade* from the A85 to the A22 at no cost.
    Would members consider this a good idea ?
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Personnaly I would stick with the A85 because of it's forth coming multi-channel aduio module, but the A22 should sound better in stereo.
    Give them both a side by side comparision if you can.
    Features wise the A85 wins though.
  3. witters
    witters
    Jul 13, 2000
    12,615
    Yorkshire
    +291
    It will only be used in stereo as I have a seperate AV amp for surround etc.
  4. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    Best try to listen to them then.
    I'd guess the A22 is better, didn't get the chance to demo them side by side when I had them at work.
