A32 with one speaker
Discussion in 'Arcam Owners' Forum' started by stevos, Jan 16, 2005.
Tags:
  1. stevos
    stevos
    May 16, 2004
    6,133
    +567
    Will only connecting one speaker to an amp damage it. If i set the balance to the far right / left will this send all the stereo sound to the one speaker?
    Cheers in advance
    Steve
  2. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    Obvious question, Why connect it with one speaker? ;)
  3. stevos
    stevos
    May 16, 2004
    6,133
    +567
    I have found a great deal on a hi-spec single speaker.
  4. Icarus
    Icarus
    At some point I would have thought that you would like to match it and get a stereo pair, If you are unable find another you would be more than a bit stuck, furthermore selling one speaker in order to upgrade or whatever may be a little difficult.
    Just a thought....
  5. steeled
    steeled
    Apr 23, 2002
    485
    28
    Maidenhead
    +54
    The balance control does not mix the left and right channels. It just controls the relative level between the two. If you move the balance to the left then the left channel is much louder than the right. There is no right channel routed to the left.
    Regards
