OneDesi
I use my AVR350 (fronts biamped) for 2-channel and AV with an Arcam DV29 and Rega Apollo and do love the combo.
I've heard the A32 is now discontinued and wondered if I should consider going down this and the poweramp route with the AV module.
My first question is:
For 2- channel, is there much of a sound difference in the above 3 amps and if so how would you describe the differences/improvements as you move through the scale.
2nd question is:
What is the AV module and how do I get it/ fit it and how much? IS it basically a fully fledged processor that needs a poweramp and if so which power amp do you guys recommend.
Thanks in advance
2nd question is:
Thanks in advance
