A2 speaker settings
Discussion in 'AV Receivers & Amplifiers' started by Taz, Mar 2, 2002.
  1. Taz
    Taz
    Hi all, a frequently asked question I know but I was wondering should I change the settings on my Yamaha A2 now I have different speakers.
    speakers are:
    Fr. B&W 603 S3
    Ctr. B&w LCR600 S3
    R. B&W 602.5 S3
    S. AE Aegis
    I have all set to small and LFE to Sub this was how my old Missions sounded the best, but the B&W's are a lot bigger.
    Taz.:cool:
  2. Ian J
    Ian J
    Aug 6, 2001
    25,630
    +4,906
    We all always seem to disagree on this one but personally I would set them all to large as they are full range speakers and handle bass well. That way the sub will handle the LFE only but as always experimentation is the key.
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Agree. No general rule here, depends on the combination AV amp/receiver and speakers. Try it out and see what suits best.
  4. Taz
    Taz
    Thanks Guys, Just an update... I set all speakers to large and fired up a couple of DVD's and it sounded...Pants!:eek:
    So its back to the old settings for me!
    Oh well, worth a try:D
    cheers
    Taz.:cool:
  5. Phil Hinton
    Phil Hinton
    Editor Staff Member
    Jan 18, 2001
    10,211
    3
    +8,312
    Taz,
    I always found with my A2 that setting to small and LFe to both was preferable.
  6. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Main speakers SMALL and LFE both? That will not be possible: if BOTH is set the main speakers must be LARGE and if I am not mistaken the amp will override this setting, says the manual to the A1 at least.
  7. General Skanky
    General Skanky
    Jul 28, 2000
    4,251
    71
    Colchester
    +44
