A1SE Upgrades
Discussion in 'AV Receivers & Amplifiers' started by BruceG, May 30, 2002.
  1. BruceG
    BruceG
    Jan 4, 2002
    9
    Bedfordshire, UK
    Anyone had their A1SE upgrade carriewd out and returned to them yet?
    How painful/painless was it?
    I'm considering having mine done, but following the threads on here I don't know if I'm any clearer about it!:confused:
    Any opinions?
    Cheers,
    Bruce
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,285
    United Kingdom
    +1,566
    A couple of members have had their amps upgraded. Mines now been done and is currently at Denon being tested, should be sent to the dealer early next week.
    They are currently on their second batch of upgrade boards with third batch due in fairly soon, they originally underestimated the demand for them.
    Make sure your dealer gets in contact with Denon (Hayden Labs) to book your amp in, otherwise you´ll be waiting. Its taken six weeks for mine to be done thanks to the dealer not contacting them when he should have and then Denon subsequently running out of upgrade boards.
    Now boards are in you should be looking at a turnaround time of 4-7 days.
    cheers
