A1SE component switching problem
Discussion in 'AV Receivers & Amplifiers' started by UVII, Feb 23, 2003.
  1. UVII
    UVII
    I just got my new plasma and was going to switch all my component feeds through the A1SE. Problem is, it doesn't work. I have tried the direct route to the plasma with all feeds and that works fine. When I switch through the amp I get nothing.
    I've checked that all cables are firmly attached and that they are in the correct order. Anything else I should try before I send the amp back for a health check?
  2. boogie man
    boogie man
    Dec 4, 2001
    233
    19
    Sunny Berkshire !!
    have you made sure that video is turn on the amp to pass the component feeds the dvd etc...
  3. UVII
    UVII
    I have made sure video is on (i.e not defeated) and I have used the video select to select the DVD (or sky,...). One thing that I have noticed, and I can't remember seeing it before, is the word 'MULTI' on the LCD display (of the amp). Not sure if I have accidentally selected some funny mode.
    All sources are functioning correctly.
  4. boogie man
    boogie man
    Dec 4, 2001
    233
    19
    Sunny Berkshire !!
    sounds like you in mult mode for mult room you do not need it on i will have a look on my amp later when missies is not watch the soaps :eek:
    Boogie man
