a11sr or 4802?
Discussion in 'AV Receivers & Amplifiers' started by patrober, Jun 14, 2003.
  1. patrober
    patrober
    I was planning my next upgrade to be the a11sr (from 3802) but have been offered a US 4802 which I believe is the same model, but with better remote control.
    Apart from needing a step down psu, is there any reason why it wouldnt work or be suitable for use in the uk?
    Anyone have experience of using a 4802 in the uk?
    Cheers!
    P
  2. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,176
    Norwich
    +796
    you are going to be looking at some serious money on a stepdown for that amp.
    this isnt going to be a £50 stepdown from maplins ;)
    Alot of industrial machinery uses 100v at 50hz so you may be able to use one of those, but then you may add alot of noise.
  3. robfitzp
    robfitzp
    Dec 12, 2002
    1,190
    38
    Bristol
    +20
    You could have a look at the Isotek Qubes - you can get those configured for American kit and although expensive, they supposedly offer a night and day improvement to sound quality.
    1kw Qube is £1200 though.....
    Rob.
  4. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,463
    United Kingdom
    +1,921
    Just so you know, the 4802 has been superceded by the 4802R now. Apart from the hassle of stepdown transformers etc you wouldn't be buying a current model.
